Engine swap BG5 GT
Paradox
Hey everyone, just a quick question. I have a 95 bg5 gt wagon. I managed to get a mint hgt-b motor, and a full manual conversion for cheap. Was wondering what would need to be done to get the bh motor running in my bg? Does it require an engine loom change? Or can I get around it by only using the block, heads and turbos, and running everything off my old engine? Can anybody do this conversion for me for a reasonable price? Im in Chch. Cheers in advance for any questions answered :)
mate i have everything you need to make yours a single turbo..
i even have a manual BG leggy already wired up for a single T, in Timaru
heres most the listings (but not everything) http://www.trademe.co.nz/MyTradeMe/Sell/Current.aspx
I have a full V3/4 manifold
ECU - matching boost noid, MAP and APS on the bracket, all vac lines
intercooler with brackets
3" down pipe
the single turbo heater pipes from the water pump
single turno exaust manifold with Up pipe
all youd need is a turbo
Thanks, but if was after a single turbo conversion I would have gone after one of them engines. Happened across a mint low kms bh motor and my engine has done a few kms so figured id use the mint block. What differences are there? How would I go about this? Suggestions, if any, would be helpful ;)
BH engine wrong compression ratio for anything bar the stock BH ECU of which the ECU plug configuration is completely differant to BG or V3/4.. or cud use after market ECU.
summary = ahole of a job
