EJ204 explain please
daddykubs
Hi all!
I\'ve been trying to get to bottom of this for quite a while now...
What is sooo special about EJ204 JDM (also sold in NZ) that it makes 190hp???
I have UK BL5 2.0R which is supposed to be 165hp.
It really does my head in. What is the mechanical difference between them?
Thanks for help
Wiki says: [some ppl blank out at that 1st "W" word]
http://en.wikipedia.org/wiki/Subaru_EJ_engine
EJ204 DOHC naturally aspirated AVCS
  • Legacy JDM BL - BP series 2003-2009 190 hp (140 kW)
Impreza JDM GC - GF series
  • 1993-1999 155 hp (116 kW)
about all I can help (I was curious what the 204 was actually in)
I\'m going to go on a limb and suggest the AVCS bit helps (which didn\'t feature in the 93-99 Imp\'s)
Thanks.
I have to say I am puzzled. Have been searching for quite a while now.
Managed to set that:
This motor was used in Legacy and Impreza SRX
Depending on year and transmission it develops 180-190hp
Has AVCS and 11.5:1 CR
You can find cars with that lump in Japan, Russia, New Zeland (not sure where else, but I don\'t know Japanese nor Russian)
I tried Wiki, TradeCarView, GooExchange, found links to JDM brochures here somewhere
Wiki and local dealer aren\'t really usefull.
What seems to be a fact.
EJ204 (MT) revs up to 7100, is 190hp and 200Nm, DOHC, AVCS
What I thought it is
Dual AVCS, WRX internals
What I suspect
Different inlet manifold, ECU, head or piston design
Prob same sort of stuff that seperates - for arguments\' sake - a "Beams" 3SGE motor from a standard one - or any number of other "upgraded" n/a motors
Higher than normal comp (and a high octane diet being required), fancy valve timing, different ECU tune, higher rev limit than the norm, lighter insides (not turbo model bits generally)
Pure guesswork here, I has no idea what the actual story would be but imagine you\'d be beating yourself and your wallet up trying to substitute the applicable bits onto a non JDM motor
On top of that You can add Cllio 192, Type R and S2000.
My car is EDM Legacy 06 2.0R imported to UK from Malta hence no data in UK dealership.
Engine EJ204LTCLE n/a 165hp (I believe) Box 5MT
11,1:1 CR, DOHC, AVCS
Now B4 JDM
EJ204
2003-2006 190hp TA-BL5
2007 180hp ABA-BL5
and revised
+1 on climate. I read this guy\'s post about tuning and living in high moutains and his hp was like 98 or something silly
But have to disagree on fuel:
JP low octane is 89RON premium is 96RON according to Wiki
GB low octane is 95RON premium is 97RON also You can get Shell Vpower 99RON (Iuse it)
