Upgrading BC5 Turbo Legacy coils to WRX coils
THUNDA
Am thinking of doing this i fit turns out my coil packs are poked
im guessing i would benifit from doing this?
anyone else done this before? i tried googling it but not much luck
i guessing the hardest part for be wiring, and would the subaru ignitor work with these coils or does it have an ignitor buit in?
chairs
 BC5RA said:
Are you referring to single bolt coils? or just any OE ignition coil?
Wouldn't the single bolt ones just fit in anyways? (V3 Heads might be a possibility for myself ones funds clear)
OE ones, the ones with coil on top and just use leads to connect to the plugs
Or what you would suggest in doing?
I suppose if you can do it for next to nothing; single bolt coils would be a mild upgrade.
You can not use the later model wasted spark setup, but after this setup in even later generation 4 cylinder EJ's went back to coil on plug.
In my opinion after all of the stuffing around the retro-fit will not outweigh the ease and benefit's of the Bosch external coil conversion.
 1992-RS']
[quote name='BC5RA said:
hey you wouldn't have tht pdf doc on your computer?? the link they have on the rsliberty forum is dead I did have it a while ago but lost it..
If you look down the page it has written it up but i'm keen if someone has / is doing this anytime soon to do a picture walkthrough guide thing :)
I might be considering doing it at a later stage.
