what power loss?
Pappu1
 funkytown said:
depends on the motor, the turbo and the current boost levels.. imo.
but generally at 240 odd i dont see you losing more than 5wkw. which could be seen as variance day to day.
2litre stock v5 motor + aftermarket turbo (i think tdo5 or td06 from memory) and link ecu, fmic fuel system etc
 funkytown said:
butt-o-meter will say it feels a touch more torquey down low, peak kw might shift left... 50rpm? no change in peak kw figure. it will be no slower / faster.
if its a td05/06 hybrid the effects are likely to be worse. if its a plain td05 OR a td06 then as above.
i will find out the exact turbo but it think running 22psi ish..
why will the hybrid be worse?
