Power on but no sound
collaboration
 Scoobydoo said:
Trying to listen to the radio with the aerial not plugged in?
Have you used a wiring loom adaptor on the car wiring side or have all the plugs been cut off?
There are no factory amps in Imprezas
Radio aerial is plugged in.
There was no wiring loom adaptor on the car side. I think the previous owner has cut it if there is supposed to be one.
Well if there\'s no plug, then I\'m guessing you are probably using wrong wiring on the car side, for the speakers.
Try these:
[table]
[tr]
[td]Yellow/green stripe[/td][td]Ignition 12v[/td]
[/tr]
[tr]
[td]Blue/red stripe[/td][td]Power 12v[/td]
[/tr]
[tr]
[td]Black[/td][td]Ground[/td]
[/tr]
[tr]
[td]Blue / white stripe[/td][td]Power Antenna[/td]
[/tr]
[tr]
[td]Purple[/td][td]Illumination[/td]
[/tr]
[tr]
[td]Brown/white stripe[/td][td]Left Front +[/td]
[/tr]
[tr]
[td]Green[/td][td]Left Front -[/td]
[/tr]
[tr]
[td]Blue[/td][td]Right Front +[/td]
[/tr]
[tr]
[td]White/Black stripe[/td][td]Right Front -[/td]
[/tr]
[tr]
[td]White/Red stripe[/td][td]Left Rear +[/td]
[/tr]
[tr]
[td]Red/Black stripe[/td][td]Left Rear -[/td]
[/tr]
[tr]
[td]Blue/Yellow stripe[/td][td]Right Rear +[/td]
[/tr]
[tr]
[td]Red/White stripe[/td][td]Right Rear -[/td]
[/tr]
[/table]
