Just wondering which fuel line is the return line in a 92 rs legacy??
1. the hose that comes straight out of the firewall to the feed lines or,
2. the hose that comes from the firewall to the canister/filter (i thnk it is) then to the injector feed lines??
and another Q...
is it ok using 2 fuel regs from a 92 rs to use in my split fuel rail setup??
Thanks.
Guest subiebboy
 QUIKGT said:
2 regs isn't ideal, but plenty have done it with no issues.
Pardon my ignorence but I have a bit of a qeustion here on the running two regs.
Why exactly is it not ideal to run two? What's the harm? What are the potential issues?
I have not had a decent answer/info on that point before and nobody seems to be able to say why it is not ideal...
 subieboy']
[quote name='QUIKGT said:
2 regs isn't ideal, but plenty have done it with no issues./quote]
Prodrive used to do it on the Group A and then possibly on the WRC cars. So I figure that its good enough to use two factory reg's on my car ;)
too late now and I aint pulling nothing more off at this stage...have just done my split rail setup with 2 regs...seems allgood atm!
