V7 STI engine/gearbox conversion into GC8 Type R - Who has done this?
 STI-007 said:
Hi Guys,
Is there anyone in NZ who can do the wiring merge if i send both the looms?
Thanks
remove the v3 one and put in the v7
or just run over it
easy and works
or print out all the loom diagrams and start from one end and do it wire by wire for the merge
its not hard but just time consuming and needs to be spot on
Hi SP00N,
Thanks for your reply.
The engine wiring is pretty much plug and play. I am just concerned about the interior harness which needs to merged to the ecu because i cant really find anything concrete on the net.
 STI-007 said:
Hi SP00N,
There should be very little from the interior loom that needs to go to the ECU.
From a quick skim through the pinouts, you may need:
Check Engine Light
Tacho
Vehicle speed
Aircon On (if you haven\'t deleted the aircon)
Start signal
IC Spray switch, if using
And obviously, power and ground.
But I can\'t see anything else in there that wouldn\'t be on the engine part of the loom.
Hi guys. Thanks for all your help.
I have finally got it running now. Had a few issues but its all sorted now.
Just a question, i am only getting 0.5 bar of boost on full throttle. Is this normal?
Is there any tuner in Auckland who does road tunes?
Thanks.
thanks kiwi_fozze :)
yep fiji..and im going to fiji soon :)
anyway 0.5 bar...near wastegate pressure... as said above...
basics i wud look at would be:
are all the lines for the turbo hooked up correct?
is there a restrictor pill in the vac line off the turbo?
is the cel on?
what fuel u using?
does it have audible knock sound?
have u used and wired the fuel pump controller thats found on the v7 sti or just wired the relay straight o pump?
no blockages on intake and exhaust side?
any exhaust leaks e.g. up pipe etc
what abt any vac leaks
or for that matter any leaks in the bov/intercooler hoses?
sort of really check all the basics first i wud say....
