WRX STI V8 Surging When On Boost
Pretty keen on a Process West one aye, I\'ve had some unforseen expenses come up so have to be carefull what I spend in the next couple months. I seen you had a HKS system come up the other day at a good price to, everything always seems to come up at the wrong time.
Anyways cheers for the help SPOON and evowrx its good to be able to bounce some ideas around. Will let you know how I get on.
its still availble
yea man damm expenses
 Steveo said:
Don\'t mind paying the money to fix it whatever the cause, I thought AFM\'s don\'t throw codes and the only way to test is with a good known unit. Have no boost gauge so can\'t really tell whats going on with boost levels etc.
Yep no codes with mine, but I had a local member plug in a tactrix cable and do some data logging, straight away could see that the value being read by the AFM was way off the figure his car was displaying (same car)
my thread is here http://www.clubsub.org.nz/forum/index.php/topic,32969.msg453946.html#msg453946
Before this I\'d replaced fuel pump, knock sensor, spark plugs... wish I\'d gone straight to the AFM, does anyone nearby hav one you can try? it\'s an easy swap. Should see straight away if it\'s fixed it
Does this happen when pulling a small amount of boost? Boost gauge will show about 10psi then drop to 5, back up to 10, to 5 and so on without any throttle movement. I ask this as my V7 sti powewred bc5 legacy does the same thing.
That\'s possibly boost controll issue as when Ecu pulls timing it pulls and to that run it does not add back
 evowrx']
[quote name='ben-jamminn said:
Ae? sent from japan? Says made in japan...its genuine by the look about genuine retail price Id say.
Like the trademe seller lives in Japan. Posted by Fedex from Japan.
Armstrong Subaru were gonna charge me double that price.
