fans wont stop running,aircon stoped working too-video
here\'s a quick video of what\'s going on,
as you can see there are no codes,iv reset the ecu 3 times just to make sure,
-problem, fans keep running with ignition off,even with one click of the ignition they keep running
-aircon also stop working all at the same time!
any ideas people?
cheers
1st video is with connects on to test codes
2nd video is without and you can here the fans keep running.
http://www.youtube.com/watch?v=7OoUbfqT5vY
http://www.youtube.com/watch?v=uWS3cyvjkFg&feature=youtu.be
If it\'s coinciding with air con stopping, there\'s a pressure switch which opens when the pressure gets too high, cuts the air con out and I think it might bring the fan on?
Don\'t make it the next thing to check but if you exhaust your options then get the air con looked at
ignition is off people : pretty sure this is an important clue of a sticky solenoid/fuse box gremlin
Lol yup definitely missed that.
I don\'t see many sticky relays, more like somethings feeding the relay winding when it shouldn\'t be, perhaps a back-feed from another circuit with a blown fuse or break in circuit
 gf8wagon said:
If there was a blown fuse for aircon would that keep the fans running tho?
Doesn\'t take much to check a fuse, worth a look.
have you pulled relays one by one to see which one stops it?
probably getting warm with A/C circuit ;). Couldnt reply to your txt the other day been super busy sorry man, maby meet up with spence one day if im around nd ill throw my eye over it if you havent solved it by then..
Allgd man,yea i found the relay that stops the fan running,stil abit weird thoe.
Marc what you mean by ac circuit?aircon stopd running the day the fans started running,iv removed the relay for now to stop it running but still need aircon on this cold mornings!lol
