wtb : Oxygen sensor and radiator
FDB272
let me know if you think of something better [ i can change it] OR at least I hope you have it registered to a PO box or business, so no one can go to the post shop and find where you live/scope the car out
pays to be a tad paranoid sometimes
This... and / or use the information opt out on the ltsa website
From pic it looks like Rev d b4
Bank 1 sensor will be same as the ones used in the v7+Sti ones
So the older models ones not going to work
There was a post here Abt getting them for much cheaper than subaru prices
If u don\'t change the sensor u will only run open loop fueling so use a bit more fuel than what u can with closed loop
How sure are u that it is indeed the sensor that\'s plate up
Maybe clean the connector plugs and reset Ecu and see
Do a running log to see if Ecu does indeed only stay open loop before shelling out for new sensor
