water in the boot
Hikari
Opened my boot today (gc8) to take out the space saver and found a massive pool in tje little ditch in the boot. Also found that there is water piled up on the right side of the boot where it has a bit of a ditch for some reason.
Has anyone had a similar problem or idea where its leaking water from? Its not from the tail lights
I had a massive leak in the boot... it was from a vent on the right hand side of the boot, that was not seated properly.
So where the jack is, but on the other side. There are rubber bungs you can remove from the boot, to drain any
water... including one right under the spare wheel bolt... get under the car to remove it.
