What is this and what does it do?
FST4RD
So I pulled the lower dash off in my GC8 wrx and unplugged the turbo timer. Now my ignition is working properly as it should. However when having a quick look around I found this little box. Seems to be a few wires coming out of it. The yellow wire has been cut.
I\'m assuming that the box is something to do with the ignition
Does it matter that the yellow wire has been cut? Everything seems to be working as it should.
 FST4RD']
[quote name='Roo said:
It\'s a relay. Might be from an immobiliser
Ah right, the car does have an alarm.
Thanks.
If it has an alarm, and the wire is cut, the alarm won\'t do anything in terms of immobilising the vehicle.
Also the sheer fact that you could get to it easily means the alarm was installed poorly.
