can some one confirm the cr ratios on a rev a ej208?
2000 legacy b4
 2000 legacy b4 said:
Oh awesome so I can convert it to single turbo and run the sti ecu as the cr ratio is nearly the same?!?! ;D Cheers bro!
if you dont realise that 8.5 is not \'close\' to 9.0 then you shouldnt be doing the swap....
its quite different and will give you disastrous results.
I am *pretty sure * the V5/6 non sti is 8.5 and the sti is 8:1. Run the non sti ecu you\'ll be fine. People see over 200wkw with them and a VFanything + 18-20psi. Noon sti probably better suited to your cams also. Like anything get it spun on the dyno when its done to check afrs and make sure its all dandy.
Besides 0.5 C/R is a big deal or small deal dpends on many things. If it expects 98 at said C/R and you run 95 you have a larger window of block ventiliation.
