FYI if you are buying aftermarket valves for V3/4 Sti shim under heads , normal EJ20 wrx/sti listings WILL NOT work as they are shorter.
So heres what you need
These are Supertech part numbers , the best pricing iv found is www.celticmotorsport.com , they are not listed so you will need to email.
SEVN-1016 Standard exhaust valve - Nitrided Stainless
SEVI-1016 Standard exhaust valve - Inconel
SIVN-1016 Standard intake valve - Nitrided Stainless
SEVN-1015 1mm Oversize exhaust valve - Nitrided Stainless
SIVN-1015 1mm Oversize intake valve - Nitrided Stainless
  • 1 year later...
