possum link and afm
driftrex
i have another question regarding possum link and wiring, can i unplug the factory boost solenoid as this wont be used, i know i had to keep it plugged in with the factory ecu so as not to get a engine check code but hoping that the link will not require it.
no airflow meter needed mate, I think they can be set up so you dont even need the factory idle control so your manifold could be real smooth!, Dont trust driving to much on the base tune either, put mine in last week and drove it to the mechanics (about 10km away) and it smelt really really rich and did not want to idle at all, used nearly 1/4 tank of gas to drive 10km!
Mechanics put it on their dyno etc and said it was fuelling enough to run a bloody jumbo jet lol, not good long term.
Did you manage to get a hand controller for yours? I had a hell of a time finding one but finally ended up getting one from an old digger that has a work shop near levels, anyhow I think he had one other there if you're after one?
yea already sorted the afm and ICV, they are long gone lol. just want to know whether the factory idle control can go as i wont be using it.
what did you pay for your controller? i dont really need one, just get the pros to tune it but depending on price.
 Swindog said:
Are they talking about the possum link or the newer ones though?
The old possumLink's can be run without using the Idle Control Valve. And as Zarnah said, it does need to be tuned to make it idle properly (also involves using the idle screw to keep the throttle plate slightly cracked open).
 Koom']
Yea that's how mine is set, I run a v5/v6 possumlink.
 Koom']
so i dont need it, correct? i dont really want the extra plumbing lol.
