BH5 GTB park lights.
Glen
I'm pretty sure they just have the one in the right side and none in the left. You'll have one in each side though Sean.
It's just that this is the first time I've had it mentioned and it's never worked in any of my previous WOF inspections. The dude seemed like a fktard though.
 subieboy']
[quote name='Glen said:
Do they have two at the front? Or were all the other WOF testers up until this one a bit blind?
Yes two at front, one each per headlight assembly...
Hmmmm. Might be time to pull the headlight and have a check then.
park lights... mine had one in each side... if im thinking a park light is what i think it is. like when u turn ur headkights onto the first stage, not all the way on... mine has a lamp on left and right side.
-smurff
yea, thts it, its a double fillament, was a pain in the bum to get led ones to replace the front two with on mind
-smurff
tht one is like wht i got, but i carnt remeber the pins set. i could... be i dont have a steering wheel to turn the wheels outa the way.
-smurff
Guest swiftbrad
you'll need ta check if its 1157 or 1156 ? Ones single and ones double. Prob need to actually take your bulb out and see.
Jaycars got these at reas price, not sure if they outta aucks though
  • 8 months later...
Park lights are turned on with the switch on the top of the steering column.
When that switch is on and lights are off you get tail lights on (but not number plate lights) and one park light at the front.
When you have the lights on the first stage (the first click on the end of the stem) you get two lights on on the front.
 Too Broke said:
NEED TO BUMP THIS UP----
How do I get to my park lights?
to replace then? i do my by turning the wheels and reaching in were my plastic inner guard would have been or jacking up thr car and going from under the car. the lights are in the lower half of the light in the guard area
-smurff
