What's the difference between GT and Spec B GT BL5???
I'd only ever own a GTB if the option was avaialable. No real idea why! In the older models like mine there are MANY little difference here and there that just make the car so much nicer. I adore the "spec.B"s
Do the BL/BP's B's get better engines like the BG/BD's did?
BL/BP GT = 172kW
BL/BP GT spec B = 195kW
Other things the GT spec B gets over the GT are just superficial... Revised spring rates, Bilstein shock absorbers, 18" lightweight alloys, thicker anti roll bars, alloy front control arms, STI 'tuned' rear suspension geometry, standard 5 speed auto or 6 speed manual, etc...
So really nothing *THAT* major.
 Hopai']
BL/BP GT = 172kW
Really? because I have a JDM 'GT' with 18" alloys, bilstein's, 5sp Manual, and from what the dealer quoted and what I have found online 205Kw.
I have seen several other GT's on tradme that have the same alloys as mine and the same alloys as an advertised spec B. Anyone know the different chassis codes?
 JoKer']
[quote name='boostin said:
EJ20 GT is 205kw, EJ25 GT is 195kw.
bakes no sense without model codes (BG/BD or BH/BE or BL/BP)
and yes I know there no BG GT 2.5's so that narrows it down
Or BF, or BH. Hmmm, whats left...???
The title does say BL5. Thought the rest could be figured out.
Don't forget with the BE/BH's, the manuals had the 206KW EJ208, regardless of weather they were GT's or GTB's. Well... says the interenet that is.
With the BG/BD's, the only 206KW ones were the MANUAL, GTB/RSB's. All other's had the less powerful EJ20H
From the factory GT Spec B is usually the Bilstein addition and a few suspension adjustments, minor engine/ECU setups and interior upholstery. ;)
