R160 lsd or not
speedfreak
 kamineko said:
yar! that large lump is the viscous coupling. :)
http://en.wikipedia.org/wiki/Viscous_coupling_unit
ah, i see, thanks for the info
ahh well, i might see if anyone wants to swap a LSD center for an Open on, seems a shame to weld up a perfectly good LSD lol
on a side note the other diff is the a way of telling if its 1 way, 1.5 or 2 way easily?
 funkytown said:
thats for cusco diffs though nick..
from memory the Subaru factory ones are sealed up.
Fwiw. hes brough the v2 sti ra one i sold to Roo :) and is asking about that diff specfically
Got it today actually :)
Lol, funny story, the diff in the second pic i already owned, so it looks like i have 2 plate lsd now, one is a 4.1 and the one i just got is a 3.9.
Should have opened it up first lol
So i now have 3plates includin the one in the rally car, plus 2 vsld the 4.44 woll go on the speedway car, plus 3 vsld with thr stub axles poking out, hmm deff time for a garage cleanout....
 funkytown']
confusing desu. didn\'t you have your r160 mech re-shimmed? how are they to do that if its sealed? i think you\'ll find the basic design of a mechanical clutch diff similar enough that the cusco info is a useful example. left/right differential torque through the spider/pinion gears rotates the cross-shaft. depending on the cam angle of the cross-shaft and the groove you end up with expanding pressure on the clutches. in my previous post you can clearly see the two different set of grooves for 1.5 and 2 way setup
you can see cross-shaft setup through holes in the diff casing, but no harm disassembling for fun
img]http://www.limited-slip.com/acatalog/waydiff.jpg[/img]
 kamineko']
yeah i assume the mechanism works the same, just need to disassemble to find out, the second pic is all i can see of the split so cant really see the shapeof the grove
