Heads.
Rosssub
 Koom said:
It\'s the inlet ports that shouldn\'t be ultra smooth as it actually decreases the flowrate. It\'s all to do with the boundary layers created as the air flows through.
But smooth surfaces on the hot side is to prevent carbon buildup which is worse for flow etc
The boundary layer of air, created by slight texture to the intake ports. Also helps stop fuel particles sticking to the port walls.
I've gone tt heads on my rebuild, just ported the inlet and port and polished the exhaust plus went shim less on a version 8 sti block. Good to get confirmation that the heads are indeed bigger than the v6 sti ones from factory, I was told this by my builder which is why I went that route.
You must be pretty bloody close to driving yours!
yes and no, only need to wire up oil pressure and temp sensors to the digital dash and sort out vacuum lines and I can start it.
However, landlord as offered us our house to buy, misses likes the house so car waits until I get money for deposit, only two months though hopefully as got some savings for it already. But its a bloody nightmare so close to finishing it and have to wait.
House>Car
Epicly close though!
  • 3 months later...
Cheers dude! I'll upload some better pics when I have had them dipped and cleaned ect. Note the cross hatching pattern on the inside of the head. This could be present on all of the phase 1.5 heads though as I have read they all use the same casting but the valve assembly is different.
Hey Rosssub do you happen to have any more information on cam identification? Or would you be able to point me in the right direction?
It would be very interesting to document all the different types of cams so we can accurately identify heads by the markings on the cams
Added a couple from my google findings
http://bbs.22b.com/forums/showthread.php?10688-V3-sti-heads-identification
http://www.scoobynet.com/scoobynet-general-1/825436-how-to-tell-v4-sti-heads.html
Nah sorry, hopefully we'll have most covered by the end of this thread. Kamineko mentioned on page 2 he was working on a list of cam markings.
  • 6 months later...
You'd have to change the valve retainers over to suit the under bucket shims. Not too bad if you have the right tools. Then you'll probably want to change to the stiffer STI valve springs as well anyway. Resetting the valve clearances takes the most time and effort.
Solid buckets will go in without changing the valve retainers, so be a better way to go. Just the solid buckets are a lot dearer if you need to change a few to get your clearances right.
Here's the BE/BH shim over bucket valve spring retainer:
Here's the V6 STI shim under bucket valve spring retainer:
V7 solid bucket valve spring retainer:
