 scottharvey said:
Where are you located easier if you check it would out
Ross is unfortunately on the West Coast.
Call a couple of Auto-Electricians if you\'re not comfortable or unsure as to what you\'re doing and explain what\'s happening & ask if they would be willing to have a quick look at it for you. Sounds like it\'s pretty minor, I don\'t doubt they\'d be able to find & rectify the cause within a matter of minutes.
Follow the negative battery cables from the battery. Make sure the other ends are connected and tight.
One goes to the Block, one goes to the F/L Guard and maybe one to the Starter?
Chances are the cable going to the Block is frayed or broken, giving you a very weak earth.
One goes battery to starter, battery to block, battery to manifold i think. Then battery to body of the car.
Theres one that goes from the body to the block, under the tmic.
Unbolt the earths, clean the mointing points, re apply earths.
I ran a wbole lot more earthing from negative post to the engine bay, and ran a massive earth from the battery to the body earth. Makez starting lots easier, idles smlother and rock solid charging voltage.
Yeh idle is a real problem with mine at the moment thanks I might start on that on weekend sounds simple n easy I have done a lot more complicated thongs on my old forester
    574.7k
