250t headers
Scott, only way you\'ll get the note you\'re wanting is to just lock it in parallel mode, which is simple and can sorta kinda work ok ish not really, and makes it sound like a non turbo suby until it comes on boost. Also doesn\'t save any gas
Other method is to just convert to single with the equal headers
Or maybe spend a buttload and fck around making some equal length headers with two up-pipe ports
Here is an amazing diagram I have constructed
Please donate to my paypal to compensate my time spent
Blue lines are when on primary only, with the exhaust valve closed. You get wub wub noise on primary only because like a WRX half the exhaust pulses are travelling like 3x the distance of the other two and they all combine rather than being smooth. The up-pipe to each turbo is in the bottom corners
When on parallel mode, in red, it all kinda has to do is go straight into each turbo - if you had it locked in parallel I suppose you could do without the crossover pipe like a TT V6/V8 motor would have, dunno how well it\'d spool anything with a 1l 2cyl feeding each (though the VR4 motors do it fine with a 1l 3cyl I guess) but could be a laugh if you made your own manifold up
