Gauge issue
When i bought my car it came with an autogauge oil pressure which never worked so pulled it out. Thinking i might throw it back in. Gauge sits hard right when sensors not hooked up and shows 15psi when its hooked up either way. Sender or gauge issue? Havent checked wiring presumed it was ok but i would expect gauge to show nil when powers on and sensor unplugged.
how can it be on/off? thats the proper sender to measure 0-Heaps PSI in oil presure, is that what its hooked up to right now?
if you 'ground' the sensor wire do you get the same results? > then faulty sender
