gtb standard boost
ajb86n
  • Replies 81
  • Created
  • Last Reply
Top Posters In This Topic
I think it is mate didnt block it off but was under the hood gave it some revs blowoff valve opened as normal but wen it closed i notched it started opening slighty again before reving again is that normal if not new blow off valve is it??
 ajb86n said:
Ok so pulled it off i dont think its adjustable so put it back on now i have lost boost in 1st turbo 2nd goes hard wen i get to 5 grand but thats when i get to five grand any ideas
I think you're expecting too much from the primary turbo tbh lol
 Rosssub']Try blocking the BOV off completely then go for a drive to see if it makes any difference, might be blowing open when it shouldn't.
You need to remove the BOV and block the hose completely, also plug the BOV vacuum hose. Then go for a drive and see if boost levels change. If boost levels change then the BOV is leaking under boost.
Sweet rossub your the man mate ill give it ago tomorrow bit busy tonite will keep u updates mate appreciate your input qnd help bloke also would this affect a hunting idle its getting worse by the day i was leaning towards coils but im getting told by a few that my blowoff valve will be the issue aswell
So ive checked the vac lines no leaks i could find ive got a brand new hks super seq blow off valve just put that on and it feels alot better but still wont boost on 1st 2nd however is still going pretty hard any ideas on where to go next
No fault codes, nothing seems out of place, chuck a bleed valve on it and see what happens
The AFM's quite often fck out without throwing an error code and will result in a hunting idle more often than not too
Yes it will affect pretty much everything, and drive it nicely because it's in "limp home" mode at the moment
That is the root cause of your problems, go get a new one, Subaru sell them for about $170
The air flow meter is the main load sensing device for the engine, without it it is basically flying blind and thrashing it with it broken is just begging to nuke it
Cheers marky havent had a chance to have a look works full on at the moment so i pulled out maf sensor gave that a clean with maf sensor cleaner put back in reset ecu code has gone but is spitting 45 now so on to the next thing
Also ive asked this before but my boost on both turbos is still only putting 7psi out gtb standard boost should be higher im absplutly lost at the moment really wana figure this out as cant afford mechanics bill at the moment any help would be great am gona do boost leak test tomorrow but any other inputs would be solid
Cheers all
Did you try the boost leak test?
Try giving the boost solenoid a good clean out, might be blocked giving WGSP. Put the car into test mode so all solenoids are pulsing again, then pump some carby cleaner through the boost solenoid as it pulses. Can also bleed the fluid into a jar to see what comes out.
The boost solenoid is up inside the passengers guard:
Yep unplugged battery for half hour before I drove it definatly feels more responsive but yea only 7 psi I'll do a boost leak test tomorrow morning also clean boost solinoid should I be looking at the waste gate aswell
