Fixing an ECU Loom Plug
GC8E2DD
In my ongoing electrical woes I came across this hokey connection which is barely holding on (perhaps three intact strands).
I believe this is crank sensor as fiddled with by the alarm. It has been cut and connected right at the plug. I'm not sure what the best approach to fixing it would be. If I cut it, there will be virtually nothing sticking out of the plug. The plug doesn't seem to open - is there a tool for popping connection/ pins out of these? Not sure if this is my problem, but it can't be helping. What would you auto sparkies do?
Yip, most plugs have a locking mechanism that holds the pins in place. Pry the locking tabs up with a small flathead screwdriver etc then the pins will pull out of the plug, (small tug with pliers on the pins wire).
So if you grab a replacement plug, with about 200mm of wire, you can replace just the broken/damaged wires/pins and solder/crimp to the existing loom.
Here's a BH/V5-6 ECU plug, the white section is the locking mechanism:
Pins pulled out:
COP loom plug:
Locking mechanism removed:
Pins pulled out:
post a photo looking into the plug and someone can use some paint skills to show how the pin comes out . the best thing about pickapart is you can have a practice haha .
or buy the whole plug u want and practice on all the wires u dont need
scientific screwdrivers would prolly be a good start
OK cool, thanks for the pointers guys. Got the same style plug at Pick-a-part, then stopped in at rumbley's and he showed me how to get a pin out. Has two little hinged caps; for top and bottom row pins respectively. Swing that out of the way, and as mentioned, shove a tiny screwdriver above and behind the pin head to release the plastic barb holding it in.
