bg radiator into bh
ajb86n
hey all
was wondering if i can bolt a bg radiator into a bh they are similar apart from bg model has 2 small hoses come of the bottom aswell as the bottom radiator hose however my bh rad doesnt have the 2 extra hoses off the bottom can i just block these up everything else seems to fit perfectly any help would be great
cheers
The system is self-bleeding to an extent like most Japanese cars. Following should suffice for you:
- jack up front of vehicle (or park facing uphill)
- fill system , leave cap off
- turn heater on, hottest temp, minimum fan
- leave engine to warm up
- allow to cool
- top up coolant if necessary, close cap
Level in overflow bottle may drop after the first few drives, this is normal. If it doesn't stop dropping then you're losing coolant.
Probably not, how's the coolant levels? Header tank and overflow reservoir. If the car is just idling when the thermostat opens then the water pump/coolant isn't flowing fast enough to push the air bubbles out. I do it this way (workshop manual).
2. FILLING OF ENGINE COOLANT
1) Fill engine coolant into radiator up to filler neck
position.
Engine coolant amount for refill:
MT model;
Approx. 7.7 2 (8.1 US qt, 6.8 Imp qt)
AT model;
Approx. 7.6 2 (8.0 US qt, 6.7 Imp qt)
CAUTION:
The SUBARU Genuine Coolant containing antifreeze
and anti-rust agents is especially made
for SUBARU engine, which has an aluminum
crankcase. Always use SUBARU Genuine Coolant,
since other coolant may cause corrosion.
2) Fill engine coolant into reservoir tank up to upper
level.
3) Attach radiator cap and reservoir tank cap properly.
4) Warm-up engine completely for more than five
minutes at 2,000 to 3,000 rpm.
5) If engine coolant level drops in radiator, add engine
coolant to filler neck position.
6) If engine coolant level drops from upper level of
reservoir tank, add engine coolant to upper level.
7) Attach radiator cap and reservoir tank cap properly.
Edited by Rosssub
BG / BH radiator have different top hose locations?
wouldn't need to blank off the auto cooling lines either? not quite necessary unless you plan to pull it out & reuse it one day? maybe plum in as a oil cooler
 Joker']BG / BH radiator have different top hose locations?
[quote name='Scoobydoo said:
Yeah this is what I would've thought too. BG / V3/4 radiator has the top hose on the drivers side of the radiator, BH radiator has the top hose in the centre.
Totally different.
Just need to use the radiators matching top hose.
is it turbo? Cos I;ve never seen a BE/BH with the top inlet on the side like a BG, pictures would help
http://www.mishimoto.com/subaru-radiator-performance-aluminum.html
[h=2]Subaru Radiators[/h]
[TABLE=width: 25%, align: center]
[TR]
[TD=class: subsectionContCell, width: 25%, align: center]
  • mishimoto-performance-aluminum-radiator-for-subaru-forester-xt-turbo-2004-2008-189.jpg
[h=3]Mishimoto Performance Aluminum Radiator for Subaru Forester XT Turbo 2004-2008[/h]Price: $440.00
[/TD]
[h=3]Subaru BRZ Performance Aluminum Radiator, 2013+[/h]Price: $420.00
[/TD]
  • mishimoto-performance-aluminum-radiator-for-subaru-gc8-impreza-1993-1998-manual-162.jpg
[h=3]Subaru Impreza GC8 Performance Aluminum Radiator, 1993-1998[/h]Price: $380.00
[/TD]
  • mishimoto-performance-aluminum-radiator-for-subaru-wrx-and-sti-2001-2007-191.jpg
[h=3]Subaru WRX/STI Performance Aluminum Radiator, 2001–2007[/h]Price: $380.00
[/TD]
[/TR]
[TR]
  • mishimoto-x-line-performance-aluminum-radiator-for-subaru-wrx-and-sti-2001-2007-155.jpg
[h=3]Subaru WRX/STI X-Line Performance Aluminum Radiator, 2001–2007[/h]Price: $465.00
[/TD]
  • mishimoto-performance-aluminum-radiator-for-subaru-impreza-wrx-and-sti-08-172.jpg
[h=3]Subaru WRX 2008–2014 / 2008–2015 STI Performance Aluminum Radiator[/h]Price: $380.00
[/TD]
  • mishimoto-performance-aluminum-radiator-for-subaru-wrx-and-sti-x-line-08-191.jpg
[h=3]Subaru WRX 2008–2014 / STI 2008–2015 X-Line Performance Aluminum Radiator[/h]Price: $465.00
[/TD]
[h=3]Subaru WRX Performance Aluminum Radiator, 2015+[/h]Price: $435.00
[/TD]
[/TR]
[TR]
[h=3]Mishimoto Aluminum Radiator for Legacy Turbo, 1990-1994[/h]Price: $340.00
[/TD]
  • mishimoto-performance-aluminum-radiator-for-subaru-legacy-2000-2004-158.jpg
[h=3]Mishimoto Performance Aluminum Radiator for Subaru Legacy, 2000-2004[/h]Price: $380.00
[/TD]
  • mishimoto-oem-replacement-radiator-for-subaru-wrx-2002-2007-subaru-sti-2004-2007-184.jpg
[h=3]Mishimoto OEM Replacement Radiator for Subaru WRX, 2002-2007 & Subaru STI, 2004-2007[/h]Price: $182.00
[/TD]
[h=3]Replacement Radiator for Subaru Impreza Non-Turbo OEM , 2002-2007[/h]Price: $165.00
[/TD]
[/TR]
[/TABLE]
Edited by Joker
http://www.silverdaleradiators.co.nz/product-category/subaru/
[h=1]Subaru[/h] Home / Subaru
Showing 1–16 of 20 results
Correct BH radiator top hose port is in the centre of the radiator. To put a BG radiator into a BH, use a BG top hose.
Same with a V5/6 radiator into a BH, use the matching V5/6 radiators top hose. The alloy block crossover pipe is still in the same location up to Rev D/V7 where the angle changes slightly:
correct i got a v6 bg rad i think he said radiator is the same in everyway bar two hoses that come off the bottom
ive just topped up coolant and heater is now working gona let car cool down and take it for a drive hopefully it doesnt over heat on me
thanks heaps for your help every1 will pop back in soon if any more problems arise
Block alloy crossover pipe angle changes to straight forward at Rev D/V7:
