when to loosen crank pulley nut?
loner
I'll be pulling my motor out tomorrow and striping it down... I am thinking
that cracking the crank pulley nut before removing the engine will be a good
idea.
What's everyones fav method... big breaker bar while in gear with the brakes
applied... or using the starter motor?
Edited by loner
If you have a power bar long enough to reach the chassis rail then the starter motor is by far the easiest and has theleast potential for skinned knuckles and hitting **** with a hammer . A 10mm allen key between the ring gear and housing will stop the motor sufficiently to undo it aswell
