Measure valve clearance with head off?
loner
My clearances are small but I've measured them with the heads off
and I'm wondering if the clearances will increase when the head in
torqued down to the block?
I have only measured one side so far, but I've got .005" to .006"
for the intake and .007" to .008" for the exhaust. Standard is supposedly
.008" for the intake and .010" for the exhaust. I read somewhere the
clearances could be reduced by by .001 to .0015 for an aluminium block
and head... also that smaller clearances was a trick to have bigger looking
cams.
Thoughts?
cams.
Thoughts?
Mine changed a little when i torqued down my last head, the deck isnt perfectly flat (but still in spec) anymore though which may have contributed. Depending on what buckets you have it's not too big a deal to sort out clearances once the heads are torqued up
shimless buckets which are $105 + gst each :(
I'm hoping the clearances open up a bit when the head is torqued, otherwise I might just cross my fingers and hope that smaller clearances was a design decision by PBMS.
I only opened the motor up to fix an oil consumption problem which I believe was due to bad valve stem seals... and compression was really good, so I don't think the
clearances were causing any problems.
