Testing idle solenoid v7-
This might not be helpful but the ECM I/O signal for the Idle air control solenoid valve is 0 or 13-14V for ignition SW ON (engine off) and the same for when the engine is on. The note indicates waveform, so i assume the signal changes with throttle application/revs/temp blah blah blah.
The info above was from a FSM for a 05 STI (might be a USDM manual) Rosssub posted for someone's BE5D single conversion on here if anyone wants to verify.
Disconnect the IACV from the car and apply 12V from the battery to it and see if the solenoid moves? don't hold me to it if it breaks though :-S
 Optical said:
Did you change your manifold? VE will change a bit so AFR changes are normal
Solenoid is closed when not energised and controlled by PWM
Nope just wired in an extreme. Not very well it seems.
Cool if its closed then im blaming avcs solenoids which looks likely. With avcs turned off it still needs a heap more fuel.
