Built long block into a 95 wrx, what can I swap over?
parker
I just picked up built engine with V5 sti heads.
It will be swapped in to the 95 wrx I have had sitting for
5 years with a blown engine.
I live overseas and just want to get the car mobile at this stage.
That means I just want to swap as many old engine parts over to the new one.
I have been out of the subbie game for a long time and cant remember much about
what injectors I need etc etc.
I need a new intake manifold. How about exhaust will the old ones match up?
Injectors are probably different eh?
Can anyone tell what I need to ask for at the wreckers?
Exhaust manifolds are same same.
G2 will help a lot...didnt see mention of that in first post lol. Just make sure you take it somewhere where they know what theyre doing and it wont be a big mission just cost money.
I would swap to V7 mani, tb and injectors tbh. Way better option idle control etc and not too much extra wiring.
It's a lot easier to just run the earlier heads and you can still make the same power. I did this in my RS legacy and it goes really well. But I guess you gotta weigh up what's going to cost you more, rewiring of half the engine bay + manifold conversion/adapter plate setup cost or swapping heads to early bolt pattern ? Would be pretty close either way I think maybe ask your mechanic/tuner see what they think. I think if you do decide to go down the re-wire path it's a good time to think about upgrading to v7 manifold as said above, then you get 565cc pink injectors which will go good with the link and tune.
I have some mint condition earlier phase one ej20r heads here if you decide to split block - Also potentially looking for v5 head/heads as one of mine is poked so could do a trade of some sort with cash your way or something - if you do go down that road let me know :)
  • 3 months later...
Just a quick update to this. The engine has been getting worked on while I was away. Hes a good tech and we ended upwith a V5 intake.
The engine is just about to go back in once I replace a few old hoses here and there.
I was going to abandon the full exhaust wrap and just go with wrapping the uppipe and down pipe. Does anyone recommend these turbo beanies?
