Legacy Sluggish When Hitting Boost
ToomTom
So I was driving around in the country side yesterday on my way home and went to pass a truck, put my foot down, the car chopped gears but the boost felt like nothing as if the turbo wasnt trying hard.... I drove it through town down an empty street again and put my foot down to see if it was still happening and little boost again, It did spool and i heard the blow off valve go off after letting off the throttle afterwards but it felt so weak. Any ideas what may cause this??
I tried re-setting the ECU by pulling the negative off the car battery and draining whats left. I left it for 10 minutes and went for a light drive, i stepped on the gas and i dont think ive ever felt so much boost from that car like ever before... probably because i was expecting no change but it seems to have solved the issue. I guess if anyone has this problem in the future they can look here and hope it works! :):):):)
 Andy_Mac']In theory, removing the negative doesn't do F all in terms of resetting the ecu the way it does with older subaru's, need to use a laptop and cable to properly reset it. You have a boost gauge on it?
No boost gauge, though one would be nice.
[quote name='loner said:
maybe you had some detonation and it went into limp mode or something?
I had a feeling it went into limp mode so you could be right.
