Any suggestions?
duncanrp
Hey forum,
So I am putting in my new turbo and I have discovered a problem... The oil return line hose doesn't seem to fit all the way up the turbo oil return pipe (As shown in picture below).
Do you guys have any suggestions on how I could fix this? One thing I thought of is possibly sliding the lower part of the hose up slightly to share its current length with the upper connection.
It probably doesn't matter, the oil is very thick, slow moving and under no pressure when it exits the turbo... just clamp it.
But as evowrx said, maybe just pull it up... or even get a longer bit of hose if it really bothers you.
The oil coming thro the return looks like its gone thro a beater hence the size. If you run to smaller return you run into issues where it back feeds thro seals.
Sure it has a bead ive got 5 or so spare ill check when im in the garage.
