Currently trying to get my old ej20 out of my bg5 leggy, and am wanting to separate it from the gbox but am not having any joy...
Have picked myself up a Haynes manual to try and make life a bit easier, but still nope.
Is there any special technique in separating the engine off the dowels, as my technique of jacking the box up and then taking the weight off with the hoist is just making the two bind up on each other at the bottom. Have managed to get the top free of the dowels and drowned the remaining in crc type stuff..
Logans car was literally tight as a nuns . Had to do what youve done . Then pack the gap at the top with chisels then lower the box and jack up the motor . Block of wood on the crank . Open some gap at the bottom . Fill that . Reverse the procedure . Was un believeable
