Boost Gauge...How To??
Hailz
Hello again all, ok I'm wanting to install a boost gauge in my 97 GTB - well to be honest I think they look uber stupid but It's more for piece of mind really, Q1 - what vac line do i tap into? can someone provide a pic so I know I'm not getting the wrong one please! Q2 - where do I tap the light wiring into?
Thanks for any help you's might give me :)
thats where i got my vacuum from.
for the light i jst pilled out the radio fuse and put the wire in there and pushed the fuse back in. may not be the best way but it worked for me and didnt blow the fuse.
this is on a b4 legacy but shouldnt be much diferent
Do you think it's very accurate?
The inaccuracy in the gauge will be greater than the differences between different vacuum lines. If you rig it to a good one it should pulse with the engine idle.
 dvs-b4 said:
i found my bov line to be very inaccurate only read -14 but when u used this line it sat on -18 to -22 which sounds about right so im nt shore bout the bov line
Same with me. Better to tap off one of the other lines than the BOV line I reckon.
 Hailz']
Also depends on how accurate your gauge is.......
