Very exiting - first preformance mod
Subru
2 minutes ago, Kiwiflyboy said:
+1 on them tyres, off to get some new ones for the legacy after Saturday's track day and finding out how terrible they are!
Yea I 100% agree with tyres for better handling but I also want a bit more stiffness in the suspension as its a NA subaru it has quite a soft setup and I would like it to give me more confidence in the corners, the sway bar has helped a lot tho. I thought about upgrading the bushes to poly but thats difficult without the tools and a pain to do. Would something like progressive lowering springs be something to consider?
Can you find any suspension from a WRX or STI from same model? That would be a good easy swap
39 minutes ago, GC8E2DD said:
I think you might have trouble bolting up the strut clevis as the STi equivalent of your car has bigger 5x114 hubs. You'd need spacers if that's the case which would presumably require a cert. Make sure you measure before buying =]
hmmm yep will do.:)
