Bad idle and stalling 99 GC8 STI
Mine did that briefly when I had an old possumlink when I was tweaking the base tune, not enough fuel on the throttle off. Do you have a vent to atmo bov? Maybe the spring is too soft, letting out air. making it too rich and just stalling? other intake leaks ?
"could" be running on 3? hows the fuel usage, coils or injector plugs etc? (bit hard & I'm only speculating)
had a thing where one injector plug 'fell' off once, had sweet lumpy cam style idle & seemed to run fine at the time but knew something was up
11 hours ago, evowrx said:
Id be inclined to say afm see if you can borrow one to try. Theyre a bit temperamental on these had endless issues with mine. Not worth buying secondhand theyre 170ish rrp genuine prob cheaper thro partsouq.
Turn your car on so its running, then unplug the afm, if motor turns off as soon as you unplug it then it may not be afm
if it does nothing when you unplug it, then its likely to be afm :)
