I am currently looking for options for a EA82T engine for my Omega RX coupe. The old motor had developed a miss and a compression test has revelled that cylinder No.4 has no compression and the other 3 cylinders are between 100 and 120 psi. They should be above 140psi. The engine has done 300,000km so to be expected I suppose.
The garage has given me an estimate to rebuild the motor of around $5-$6k which I suspect is a little high.
I did see that there is currently a EA82T engine for sale on trade me but really want to try and pick up a motor in the south island if I can to minimise freight.
I am just looking to getting the car tidied up to sell.
I have nothing suitable, and i am in the NI,
Only engine I have that I would be willing to part with has been sitting outside under a cover for 5 years so dont know how good it is.
5-6k seems high,could be a burnt valve causing low compression I would be investigating further
I will check out engine rebuilders in Christchurch. I may also check out a EJ repower option although this is not the preferred option as the car is a NZ new car which makes it even rarer than the RX coupe already is.
