Power Steering
My steering light has been on for quite some time and my power steering is gone. I'm just wondering if its dangerous to leave it for a long time before getting it looked at?
Will not getting it fixed soon while continuing to use the car further damage things?
(i don't know where brake booster and pump is :'( )
Check if there's a wire coming out the back of your PS pump. If there is, make sure its connected. Also check under the brake booster for a wire going down to the rack, and again, if its there, make sure its connected.
Otherwise, GET IT SORTED ASAP!! No power steer is dangerous!!
sorry to hijack but what does that wire on the power steer pump actually do? my original v2 pump has it but ive since mixed and matched pumps/tanks/pulley and the new one doesnt have this wire so have left it unplugged and nothing on dash comes up or anything?
does it do anything?
Haha, I broke my wire off replacing the pump the other day, was a pain in the ass trying to solder it back together where it broke...
  • 3 weeks later...
$2000 for a new power steering computer said the mechanic..or need to find a 2nd hand one with the same numbers. Does anyone of any knowledge of this part and the number thing?
If i can't find one i guess i'm gonna have to get a new car since i won't pass wof :-\
They do indeed have a P/S ECU. Silver box attached to the underside of the steering column.
Boomer - have you had it sent away to be fixed?? Try Anything Electronic in Nelson.
I was abit worried i was being dicked around but "boostin" confirms im not. thankfully i got a call and they found one that will work and its only 268$.
The mechanics is called newtown auto electrical. in wellington.
Thanks for the replies as well guys
Jesus christ thats expensive, you can buy whole parts cars for that. Id call a couple wreckers if i was you and double check their numbers
 leggyfreak said:
6 bux from pick apart i have gone thru a couple of them given up finding the reason y
They all have issues. Mine included. I've just learned to drive around it!! ;D
