clearance of calipers
is there ever to close for the calipers to be or is it sweet as long as they dont touch,tried my brembo fronts today and shes a tight squeeze prob 2-3mm in some places,they actually hit the bleed nipple flap bit.if there is a limit to safety can i just get some small spacers are they even legal?do they need to be certed?heres some pics cheers guys/gals  alt=
 alt=
 alt=
 CUDDAS said:
man that's close, all i can say is make sure your wheel nut's are tight & caliper bolts too, +1 on the spacers- not sure about cert.
what size rim are you running, & offset
I'd like to get some red brembo's from an evo presuming they are the same type as your gold one's only diff being the colour i hope. :)
got 17s bro dont know the offset though,had the same prob when i put my 4pots on my old 17s (not quite as bad)but then put these wheels on and had HEAPS of room,was pretty optimistic they would fit brembos,until i pulled them out of the box,they look pretty big on cars but when your holding them dam they big,the calipers like the size of my head and you gotta be a weight lifter to pick the discs up.i dont think youd be able to use evo ones unless you got a custom bracket made up,i could be wrong though,go for the win bro gold all the way
 JoKer said:
on safe side - there are some spacers which are legit, grab some 3mm ones just in case, minum is 6-9 complete turns of wheel nuts IIRC for a cert guy to accept them
where can i get those?must be good old trademe,am a bit worried about putting them on otherwise.
