Hi team,
I’m in need of some help and advise. I’m trying to put a V5 sti ecu into my V5 wrx. The car cranks but won’t fire. My guess is the fuel pump isn’t working as I can no longer hear it prime. Iv read things about moving pins around in the plugs but cannot find a diagram that resembles my car. Can anyone shed some light on this??
Don't use it it will knock like crazy. The v3/4 stuff is fine but v5/6 doesnt work. The actual not firing is cam/crank triggers iirc nzdm vs jdm.
36 minutes ago, Jdelahaye said:
Found a helpful diagram online
wanna share here? Could be useful for future tuners :P
Are you saying you can use the V3/4 sti ecu in a V3/4 Wrx, but not the V4/5 Sti ecu in a V4/5 wrx.
Would you need to get the STI crank/cam triggers to get it working correctly
3 hours ago, SpeedySub said:
Are you saying you can use the V3/4 sti ecu in a V3/4 Wrx, but not the V5/6 Sti ecu in a V5/6 wrx.
Corrected the first portion. The reason you can't use it is it knocks. It actually runs.
The wiring issue is due to the immobilizer iirc. It's simply cutting and switching a couple of wires to get it running. Pretty sure Nzdm vs jdm.
Ah I see now. Thanks for the explanation
