Hi all,
Successfully put in my sub last weekend and it’s been sliding around all week.. oops.
The subs dimensions are roughly: 40cmH x 40cmW x 50cmD. It’s 30-35kg so I think bungee cords won’t do. I want it so sit on the left at the back preferably.
has anyone done anything similar or know if there any areas in the boot that I should avoid drilling in too? Any tips/discussion appreciated.
cheers.
Look under the car... there isn't much to avoid. Exhaust and chassis rails is about all. You can actually put bolts through the chassis rails, but they
would need to be really long. Make sure you use plates on the underside of the car as the steel is pretty thin.
In my 3rd gen sedan I just used L brackets bolted to the chipboard-ish floor liner then bolted to the sub box with one attached in the same way to the seat back. Worked like a charm for the year+ I had it in there.
You got a pic of the box? Is it just one of the semi generic cube one's with one face chopped off at X angle with an opening?
    574.7k
