Having a go at re-doing the Nexus 7 install in the legacy.
This time I have a better condition Nexus 7 2013 LTE model and using an FTDI chip based VAGCOM cable.
Running the timurs rom, OTG cable, FI mode etc etc.
When ignition off, I notice the OBD2 port is still powering the Cable (red LED on). From memory my old cable never used to have this issue. When switching off the ignition it would all power down the cable as well.
Have I missed something here, or should I chuck a relay on the OBD2 port wires so the live battery wire is only active when ACC on so it doesn’t drain the battery too much ?
Edited by logan25
