GT with 2 Problem - Your Ideas?
Bazza-NZ
Hey
2 Problems, not sure if they are related or not... probably not
1st Problem
Suddenly my car has started to surge at low rev with a little bit of load, its occurs around the 2,000-3,000RPM mark, once the turbo kicks in she is away,.. It does it in every gear and is starting to annoy me a little now. 1st gear is the worst but I'm assuming that is to do with the short ratio.. it feels like i am jumping on the throttle then jumping off it again if that makes any sense - Code 52 is all i get
This only happens when i have the manual ECU in the car, my car use to be an auto and doesn't surge with the auto ECU in
possible items you can think of?
2nd Problem
It still doesn't start well. still takes ages to start but will start after cranking over, I have replaced:
Fuel Pump + in tank and in line filters
New Battery
Battery Terminals and added 2 extra grounds
Square box by boost controller (forgot what it is called right now)
Still takes a while to start, starter motor cranks fine and giving it a bit of a whack doesn't help.. Car will start fine after its been running for a decent amount of time [engine hot]
AND
Starts perfectly fine if i leave it sitting for 1 - 1.5 days.. so if i leave it for a while hop in it the next day or so it will fire over first time
Any ideas on this issues
I'm getting some parts tonight to see if they fix it.. they are
oxygen sensor
AFM
set of coils
Maybe i am missing something??? i'm lost at this stage i have replaced most of the usual stuff but still just will not start easily, am i missing something
Try starting with your foot flat on the floor. Coolant temp sensor points to starting issues. Id stick with the Auto ECU. On a BC it doesnt make a whole lot of difference which one you use does it? Mine ran fine for a long time using the Auto.
Throwing new parts at it without stopping to think first is just going to cost you money and not get anywhere.
1st problem.. can you get a voltage reading on your TPS, mine was hunting in the same range, and its becuase the tps was dying.
when on constant trottle the voltage is bumping up and down slightly making the ecu respond by increasing/decreasing the fueling thus making it hunt/surge.
lucky for me the link gives you the voltage readings directly.
* I think its the TPS, either way im referring to the little black device on the right hand side of the manifold right next to the throttle body (on a V3). ((i know it swapped sides in the version 5/6)) (((unsure on the BC legacys where its located))).
Problem 2 -
could also be TPS, mines a **** to start cold as well.
TPS is a bitch to set in the correct position im faily certain - you have to remove the IDC and the intercooler to get to it. then adjust to get the right voltage readings at idle.(on a factory ecu).
The link is much easier to do - So Rick tells me.
 keltik']
Only switched over the ECU as trying to fix the starting problem... i find that i get better fuel efficiency with the Manuel in that i did with the auto
Problem 2 -
Hmm i've got a multi-meter will investigate this tonight and see if it will make a difference
2nd problem likely to be temp sensor but could also be a leaky injector releasing the pressurised fuel in the fuel lines into one of the cylinders, which would explain why if yoiu left it over a few days it would start first pop because that leaked fuel would have evapourated
Was thinking about this actually, is there any way i can test without taking everything off?
Will do temp sensor as its a lot easier to do
not really any way to check a leaking injector without taking it out, its easy to check if the injector is working (stethescope / skrewdriver to ear way) but you'll need to take the injectors out and get them cleaned in a high frequency cleaning thingy, or just get some 2nd hand ones, probably gona be the same price but its a bit of a risk buying 2nd hand injectors i rekon
replaced the coolent sensor but still no luck.. i have managed to pick up a set of second hand injectors so will be putting them in sometime in the weekend to see if that helps... i'm hoping as i'm running out of ideas and things to replace / test
TPS sensor i still need to test yet
Surging has gone, replaced AFM, 1 coil using the eye-meter inspections and O2 sensor so that seem to have fixed it for sure
so just down to the starting issue now :)
  • 3 months later...
Guest jakesternz
 THUNDA said:
thats IF its not temp sensor, it is very likely to be temp sensor though, they can cause all sorts of dramas when they crap out
what are the symptoms of a failing temp sensor?
A fluxtuating temp reading?
 jakesternz']
with my experience with temp sensor, they either work or don't
fluctuating temp reading could be due to a number of different things such as:
Air in the cooling system
Ground wire not secure
Plug not connect fully
For a start I'd try re-bleeding the cooling system and see if that helps
Since this has been brought back out from the dead fixes for both if anyone else experices any of the above problems
Problem 1 = AFM dieing causing an overfull during low rev, which then the car struggled to pull itself along (semi related to problem 2)
Problem 2 = Bad starting due to a number of leaky injectors, would overfuel the car all the time, 90 bucks got me just under 300km a tank most time
Guest jakesternz
I having similar issues. Tried starting with foot flat on the floor and it started and stalled?!?!?!?
Any ideas now?
Guest jakesternz
 Bazza-NZ']
Its not a huge flux, but does go up and down a bit. I will check for these problems.
Where should the TEMP gauge be sitting during normal operation?
 keltik said:
Mine sits exactly between those 2 marks and no matter what i do - it doesnt move at all. Its a H6 tho...
Same here on my non fancy gauge, about half way or just a little under the half way mark
fancy gauge is dependant on what i'm doing with the car at the time
Highway driving = 65-70oC
Town driving = 80-90oC
then after turning the car off it spikes a little to about 95oC
