Which Legacy to get........
I'm partial to the '03 onwards as well (BP/BL). Used to like the older shapes, but for some reason have "grown" out of them. That tradecarview site is a lot of fun to look through. Think i know how i'm gonna be spending my day now :) Already found a WRC edition 2000 Type R (0295/1000) that looks in mint condition... whole new world of possibilities!
If i see a nice BP/BL in your price range in my searches, i'll let you know
(Edit: Sorry this isn't on topic, but there's a bunch of the ltd edition Type R's on there, price range from $10k to over $20K)
 GravelBen']
[quote name='jake_the_muss said:
the engine "optimization" between the '99 and '02 models is pretty much nothing. the only time it was truly "optimized" was for the S401, which you aren't looking at. Other than that, consider all the B4s to be pretty much the same, mechanically.
Rev D (01 facelift) has different ECU, different turbos, higher compression, and so on. Significant differences.
'01 and up ECU's can be reflashed, previous ones can't. turbo differences as well. end result? correct me if I am wrong, but you still ended up with 205 kw (280 hp). little bit different feel, but I haven't heard of any differences that would make one year stand out against the others, except for the S401.
 boostin']
[quote name='GravelBen said:
Rev D has 9:1 compression - A and B are 8.5:1, not completely sure about Rev C.
No, EJ206 is 8.5, EJ208 is 9.
My 2001 e-tune (revision d) has the EJ208 under the hood.
VOD is practially nonexistent in my '02 E-tune - I guess it could be down to individual car differences but I've heard a lot more VOD complaints about older versions. Agreed that its mostly small incremental improvements for each revision though.
Buy it if you can it looks immaculate, the gear booot even looks new. No coin scraping in the tray etc. Would be a good buy if you were to hang on to it.
Which car were you talking about?
