crank and pistons
Pappu1
been thinking on this for a while but unsure so here goes:
is it possible to transplant a v7 sti engine setup in a closed deck rs block
i mean v7 crank and rods and pistons to a 89 rs block
the v7 are rear thrust bearings and the rs is center thrust - whats the dam difference anyway?
and also, will v7 sti heads fit the transplanted rs block?
what other heads will fit? - v7 wrx? v4 wrx?
chers for the info!!
Yes you can but your going to have have the block machined to accept a rear thrust crank.
The diffence is where the thrust bearings are - ie rear of block , centre block.
The heads will fit on.
Given it will cost $$ to get it to fit the rear crank you need to answer the question do u need a cdb.
 pappu said:
ahh thanks for that..
pretty much the v7 sti internals will fit strait into a v5-7 block right..?
thats without having to make adjustments for the bearings as per the old rs blocks..
as long as the block is still fine
 wrx_lou said:
Have you thought of getting your orginal block closed?
true isnt v7'8'9 technically semi-closed deck's any way and can handle 25 +++ psi or so/ and closed deck's iv been reading are only realy good for ppl working towards over 500whp.. you could just spend lots and get a v7 Spec C block ;) or or or stroke a EJ22 to get 2.8L and go nuts ;D
 keltik said:
How exactly do you stroke an EJ22 to get 2.8L?
lol ej22t sleeved bro, crawford performance still use ej22t with a stroker kit and out there cam's bullin or bulin or buelin cam something like that cant memba was a wile ago when i read it somewhere, was frekin awsome tho..i will try to look for the articl for you post it up
