Breaking into my B4
Jord
Hey guys,
I feel like a bit of a twat but ive managed to lock my keys in my boot while cleaning my car (opened boot without unlocking rest of car then closed the boot, forgetting the keys were inside). Does anyone know the easiest way to break into it without causing damage? If i remember some of the the older version legacys had unlocking sequence that could be activated by the right sequence pulls on the door handle.. Does the b4 have this? Could possibly work if the code has never been changed
Feel free to send me a PM if you have any tips as its probably not the best idea to publicly share the best way to break into a b4
B4 does - but unless you set it you cant enter like that, pull window open at top and use wire to unlock latch
or slim-jim the lock (steel ruler + wire trick (untested)
or jam a flat head into the lock and twist - they are very weak (slight damage)
 JoKer said:
B4 does - but unless yo uset it you cant enter like that, pull window open at top and use wire to unlock latch
+1 to pull the window and use some wire.
Yea i managed to get a coat hanger wire down inside but the lock release needs to be pushed inwards to unlock... where as it only needs to be pulled out on my old bg5 which was a piece of piss to open.. Guess Subaru learnt there lesson with that one :D Guna find a longer piece of wire and try to reach the boot release latch
