Replacing a Steering Rack Boot
GC8E2DD
Easy enough, best to get a wheel alignment done afterwards if your not confident.
Assuming its the same job as on a Legacy;
Youll need a few different size spanners, 14mm, 17mm, 19mm and 24 i think. Dont quote me on that though.
Mark the threads of your tie rod with some spray paint or some electrical tape so you know how far to tighten everything back up once youve got the new boot on there.
Jack up, wheel off, pull the boot off the steering rack end and undo the tie rod, unscrew the tie rod and slide boot off, replace with the new boot and reassemble everything.
 funkytown']
[quote name='GC8E2DD said:
Thanks for the offer Funky. All things going to plan Viv and I are going to do both my coupe and his GTB tomorrow night after work.
Sweet as dude. I still gotta go round and see his FMIC setup
Cars in at Shred at the moment if you want to look at it...
I did this on a leggy last night, got those "stretch" style boots that slip over the tie rod end with a sock, saves you from having to undo the tie rod end and mucking up your wheel alignment. Worked mint and only took 15mins
