auto trans issues
dubbedup
Gidday guys,
My mate is having probs in his early 90's legacy, it is not shifting gears well in auto mode, is fine 1st & 2nd but needs to be backed off to get into 3rd(and driven like a manual), he had this problem diagnosed as a sensor that aparanetly lives in the gaurd, altho it could also be the trans computer, which is a 2AA.....any ideas what this sensor could be? or where exactly i could find it,
At this stage its as much info as i have.....
You get the trouble codes by moving the transmission shift in a certain sequence.
Look here... http://codes.rennacs.com/plugins/SubaruTRANS/SUBARU-TRANS-LEGACY-CHOICE-SVX.php
Oh yeah, there is no sensor in the guard.
If you have had two recond trans then there must be something else wrong with the car causing it, those things should be good for a quarter million Kms.
If you are throwing in second hand ones... Don't! They only have about eight hundred dollars worth of wearing parts, seals/gaskets in them. Find someone that can overhaul one for you.
 boostin said:
There are no sensors in the guards...?? ???
Sounds like a toasted trans to me (I did pop 2 before I went manual...).
maybe they are thinking of speed sensor's? Two i think !!one is part of the cluster and is driven by the drive adapter and than the speedo cable up to the speedo assembly or somthing like that and the other is in the tail shaft of the transmission, but you should of got chk lght i think
dying clutch pack.. ???
my gf has a little mazda with similar faults.. told by a mech that its the box dying... something about having to back right off putting less torque through the box allowing the dying clutch pack to pick up the next gear.
Hers wont even pick up 4th when its stone cold.. hoooons down the motorway in 3rd - a rather funny experience..
*UPDATE*
ok so the wof/reg just run out, and too save tickets my mate got a cheap car (BD5) and i just sussed a deal to get this cheap. am getting it tomorrow, will try and extract codes or get a better desc of whats going on, otherwise i will covert to manual altho id lie an auto so the mrs can drive it,
ok this is a BF5 model and its doing the following:
almost undrivable in auto mode, but in manual mode you can drive it in 1 and 2 but when you put in 3 it stays in 2 and when you go D it just feels like a slipping clutch.
Have also noticed that the speedo doesnt go, could this be affecting it? do these have a speed sensor unit as it has not thrown any check lights as of yet.
Is this trans totally buggered? (havent checked auto codes yet)
it sounds buggerd hahaha, not sure whats wrong with it, the feels like a slipping clutch is the feeling i got before mine died, then all of a sudden going up a slight hill, it just started free reving, no gears worked, was pooed.
as to your totally buggerd question. . . some one else who actuaaly knows what this problem is will have to answer
-smurff
  • 3 weeks later...
My mates mate reckons he has everything for a manual coversion for $400 IIRC, altho my whole conversion only owes me $250 and all i have to do is get gearbox fliud and clutch fluid.
Only took me a day to swap everything over, and that was on the ground using jacks etc
