injector ratings
wildturkey
My calc is very home made but works:
power = # of injectors x flow/8.45 Was a slow day when I worked this out
so 440s are commonly known to max out about 210 @ the wheels.
4 x 440/8.45 = 208 seems good,
some one on here also maxed out some 740s at near 350 @ the wheels soooo....
4 x 740/8.45 = 350 I think that proves the theory
Im sure it depends on the dyno, fuel pressure, and duty cycle a lot more than my formula will ever hope to compensate for but its a good starting block. These are very much MAX figures on std 3bar fuel pressure too.
Old thread i know.......
A general rule of thumb, it takes around 5cc of fuel to make 1HP
Example: 500cc = 100HP x4 injecotrs = 400HP MAX (@ 100% Duty)
Then you need to worry about "Duty Cycle"........
You wouln't want to run more than 80-85% Duty cycle
Anyway you get the picture.......a little bit of math and you can sort what size injectors you'd need to match your needs
