STI RECAROs FINALLY FITTED IN!!! PICS INSIDE...
yes it fits!
first picture is a pencil draft of my car
done by my girl friend, nothing much, just showing off. :D
i love the new seats, makes me sit on the floor.
and the sides are very tight.
the moment i sat into the new seat
i could not reach the steering wheel lol
cos it was too low. then i remembered that my steering wheel is adjustable ;D
the new seat takes abit more room on the back though...
which means no pew pew at the back of the car with a hot asian biatch. :-[
my old seat is for sale
and my new seat is also for sale
pm me if interested, cos i want to get carbon seats.
i dont have the seats in my hands right now
damn.. if i do i would just try it on
but still waiting for the seller to contact me.
if it will fit then ill just jump to his house
if not then ill have to txt him say that im not going to buy it
just got them today
fitted them on no hassle
seating position is low as now
recaros holds me very tight.
feels like driving a new car now lol.
rides like a dream
will take some pictures tonight
eventually the seats was not off a version 11
it was bought from the subaru-sti.co.jp web site
which is a sti/recaro seat.
they sell for $1133 USD per seat including rails on nasioc.
ive got them for 250 good old NZD.
:D btw its brand new
i dont think its anything to do with the air bags.
its the diffrence in the seat rails (because the shape of the chassis has changed).
try use that seat on ur old rails.
and see if that works
i would suspect, that if the seat has an air bag, and you install it in your car, and the airbag wont activate in a crash. it wont pass WOF, as all safty devices need to be operational IIRC
-smurff
why wont it pass wof????
his car dosnt have factory air bag seats anyways....
its like replacing a factory non-air bag spec-C steering wheel
with a air bagged steering wheel (air bag not working).
i think my logic is right
just that the seat rails wont fit
nothing to do with air bags i believe
i found this :
2.4 Airbags
2.4(1) This clause applies only to airbags designed to protect occupants in the event of a frontal impact crash.
2.4(2) Except as otherwise provided in this clause, an airbag and its operating system must not be removed from a motor vehicle or rendered inoperable.
2.4(3) An airbag may be removed temporarily for the purpose of repair (either to the airbag or to another part of the motor vehicle to which it is attached) or replacement.
2.4(4) If the retention of an airbag could pose a risk of serious injury if the airbag is deployed, the airbag and its operating system may be rendered inoperable in, or removed from, a motor vehicle:
(a) that has been modified to accommodate the needs of a person with a disability; or
(b) that has had extensive modifications made to its frontal impact structure, for specialist use.
2.4(5) An airbag may be rendered inoperable in, or removed from, a motor vehicle 14 years or more after the date on which the vehicle was first registered in any country, provided that the vehicle is then certified in accordance with 2.4(6) or 2.4(7) (as applicable).
2.4(6) A light motor vehicle whose airbag and airbag operating system have been removed or rendered inoperable under 2.4(4) or 2.4(5) must be certified in accordance with the Low Volume Vehicle Code.
2.4(7) A heavy motor vehicle whose airbag and airbag operating system have been removed or rendered inoperable under 2.4(4) or 2.4(5) must be certified by a specialist certifier in accordance with Land Transport Rule: Vehicle Standards Compliance 1998.
2.4(8) A switch may be installed in a motor vehicle to render an airbag temporarily inoperable, and the switch may be activated in circumstances where the deployment of an airbag could pose a risk of serious injury, provided that the switch:
(a) was installed as original equipment by the vehicle manufacturer; or
(b) is retrofitted and certified in accordance with the Low Volume Vehicle Code.
2.4(9) A motor vehicle must not have a sign, light or other device that indicates it is fitted with an airbag, if it is not fitted with an airbag.
2.4(10) If a device specified in 2.4(9) is not able to be readily removed, a label that indicates an airbag has been removed must be permanently attached in a prominent location where it is clearly visible to any occupant in the seating position previously protected by the airbag.
2.4(11) A motor vehicle must not have a light or other device indicating an airbag operating system is operable if it is inoperable.
2.4(12) An airbag warning-light system, if fitted by a vehicle manufacturer, must remain operational.
they talk about rendered inoperable, an no operating airbag fitted to a car would come under this i would say.
-smurff
