legacy conversion problems
rex-leggy
You're not doing it twice, this is just information gathering...
I have yet to find a conversion pinout diagram that converts a 4 plug directly to a 3 plug!
Maybe I'll draw up my own once I've done it and ironed out any bugs, then post it up for all to use ;)
Yep, it's also been established that the 4-plug plugs plug into 3-plug ECU, and there looks to be an equal amount of re-pinning to do (about half ish) So really, i reckon it would be foolish to go with 4-plug ECU, when you can get a 3-plug in there with the same amount of hassle. The one thing about the 3-plugs are you will need to get yellow injectors, and a compatible air flow meter.
Wiring wise, take a look at this PDF, and the northursalia link above
ECU Pinouts BC5/BG5a/WRX 4-plug.pdf
Also, the GTB 3 plug is the same as the impreza 3plugs, only it has 4 ignition wires not 2. Regardless, it may help to have both. i fount the little diagram at the top of the gtb one very handy
97-98 ECU pinout.pdf
 teamnicknz said:
Oh dude u got the same ecu as me 7c but mines yellow (dunno what that means) im making an adapter up as well to suit the v3/4 sti ecu i think ive almost got it all sorted apart from a couple of things, will keep u informed.
thanks dude!!
 ReubenH said:
Yep, it's also been established that the 4-plug plugs plug into 3-plug ECU, and there looks to be an equal amount of re-pinning to do (about half ish) So really, i reckon it would be foolish to go with 4-plug ECU, when you can get a 3-plug in there with the same amount of hassle. The one thing about the 4 plugs are you will need to get yellow injectors, and a compatible air flow meter.
hmm not sure wat to do now . could get expencive having to do injectors?
Nah you'll be sweet if you stick with an ECU from a standard WRX or Forester, you only need to upgrade injectors if you're running an STi ECU and turbo. I might have a spare Forester ECU if your interested, PM me.
What Turbo are you currently running? Mine is just a VF10 and it goes quite well running on the greys and Mines TT ECU!
i was runing a vf8 .got a downpipe made.
but i bew the turbo up on sunday (guttd!!) theres a nasty noise from the turbo like the bearings gone.
so im looking at replacing both now. i might aswel do the lot now ae? save me from having to do it later haha
ive put up on the wanted thread that im looking for a turbo to but dont no weather to go for a tdo4l .
anyone know anything about these turbos . is it better than a vf8?
Well the whole point of upgrading to 3-plug is the injectors and tune of the STi 3-plug ECU's
I'd only go with a fozzy ECU if you planned on upgrading to the STi and yellows later.
Oh and get a VF39 au, they haul :P (i got mine for $300 from a guy named paul, i can give you contact details if you want)
That's what my plan is - convert to 3 plug and use a standard WRX/Forester ECU while I still have my EJ20H (std cast pistons etc) in the car, and then when my forged STi engine rebuild is complete I'll upgrade injectors and use an STi ECU with a decent turbo.
keen if it fits? wat sorta setup would i need ? and wats a vf39 out of?
